Use the following procedure to display IPsec information on an interface.
Display the IPsec status on a VLAN interface:
Switch:1>show ipsec interface vlan 22
VLAN Interface Policy Table
Vlan Interface Policy Name IPsec State Direction
22 AAA Enable both
22 tcp Enable both
22 icmp Enable both
The following table defines parameters for the show ipsec interface command.
Variable |
Value |
gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
loopback <1–256> |
Specifies the loopback interface. |
vlan <1-4059> |
